There's a small selection of fairly expensive ebikes at: Stevens Bikes 2012 | Home if you have a couple of grand to spend on an ebike. I don't recall seeing these models in the UK.
Indalo
Indalo
Prices were on pages illustrating the individual bikes Eddie. The ones I looked at were all over €2000 but that seemed reasonable to me considering what UK prices are like for better quality machines.I did not see prices?
If you plan on spending most of you time unassisted and you should, then a hub motor is out of the question. The wheel set on a bike is very important and a hub motor compared to a normal wheel creates a lot of drag. I made the mistake of getting a bike with a hub motor and I have regretted it ever since. I have since then tried a MTB with a Bosch center motor and I firmly believe that is how a ebike should work.any comparison available? I'd like to buy (or adapt) a e-mtb but not sure which one is better. Bionx 350 only available in the US (and cheaper) where I travel often but due to the new international regulations lithium batteries cannot be checked-in so it must be shipped via sea. What about the Bosh? Is the Bosh mechanic transmission system more effective and balanced than the Bionx' magnetic one?
I don't think geared hub motors create a lot of drag necessarily. The system you bought perhaps does. It depends on the motor.If you plan on spending most of you time unassisted and you should, then a hub motor is out of the question. The wheel set on a bike is very important and a hub motor compared to a normal wheel creates a lot of drag. I made the mistake of getting a bike with a hub motor and I have regretted it ever since. I have since then tried a MTB with a Bosch center motor and I firmly believe that is how a ebike should work.
Your motor's a direct drive, which is why it has a lot of drag. Geared motors have clutches, so drag is negligible. Don't condemn all hub-motors just because yours is bad.If you plan on spending most of you time unassisted and you should, then a hub motor is out of the question. The wheel set on a bike is very important and a hub motor compared to a normal wheel creates a lot of drag. I made the mistake of getting a bike with a hub motor and I have regretted it ever since. I have since then tried a MTB with a Bosch center motor and I firmly believe that is how a ebike should work.
I once bought a specialized bike with a shimano WH-R550 wheel set, the bike felt heavy and sluggish. So I replaced them with Fulcrum racing 7 wheels and the bike was transformed into something nimble. So in my case I can feel the difference between two non assisted wheels. Now a ehub wheel does not come even close to the performance characteristics of a normal non ehub wheel. To some people the difference doesn't matter, but I am of the opinion, that if you try it, you don't go back.Your motor's a direct drive, which is why it has a lot of drag. Geared motors have clutches, so drag is negligible. Don't condemn all hub-motors just because yours is bad.
Bionx is also a direct-drive motor.
