Bosch power pack 400
Greenerboy
Jun 9, 2020
Hi I’m looking for advice . My wife has a Matra (French) pedalec and I put the battery on charge to discover it was dead. No lights appear on the Bosch Powerpack 400 rack battery even after an attempted reset. How can I determine whether it’s charger or battery? No light on the charger to indicate whether working or not. Thanks.
GLJoe
853
407
UK
Easiest way is to find someone else or a dealer with a Bosch powered bike and swap batteries/chargers.
If there is no light at all on the battery when pressing the button in, then chances are its probably that though.
6,724
if the batt wont light up then the bms is dead and a bin job as no way to fix that and bosch dont sell bms boards.
the charger wont turn on until it connects to the bms so only way to test it is with another working battery.
Greenerboy
Jun 9, 2020
Thanks for the advice. Not looking good
Greenerboy
Jun 9, 2020
Thanks for the help. Doesn't sound at all promising.
8,790
Even if you were to send the battery to Bosh they will just bin it, my brother tried that route years ago. Bosh will not entertain any repair.
Reactions: Greenerboy
6,724
they can be recelled if they have a working bms but as it wont even give a error code means it is most likely a dead bms.
there are 40 cells inside the pack if you can make use of them.
