Bosch powerpack 500 battery
Rich b
Sep 5, 2019
Hi ,
I have just inherited a cube e bike. It is a 2017 model with a bosch powerpack 500 battery HYBRID POWERPACK.
Can anyone tell me if these batteries are still available or if there is anywhere they can be refurbished. E.g. new cells.
Many thanks.
6,723
2,836
I suspect the it's the bike that is hybrid rather than the Battery.
The battery would be a PowerPack.
If it's a rack one:
https://www.merlincycles.com/bosch-powerpack-500wh-rack-battery-303236.html £350
If it's a frame one:
https://www.merlincycles.com/bosch-powerpack-500wh-performance-frame-battery-107834.html £600 is overpriced
https://www.merlincycles.com/bosch-powerpack-725wh-frame-battery-329288.html £500 has higher capacity
https://www.merlincycles.com/bosch-powerpack-400wh-performance-frame-battery-193912.html £300 has lower capacity, but if it is enough for you it is much cheaper.
I'm pretty sure there were just the rack and the frame PowerPacks around that generation of bike,
and that the different capacities of the same style were all interchangeable.
I also thought that 600wh was the biggest of that generation of battery so I may have got confused somewhere along the line,
so do double-check before buying, especially the 725wh.
I replaced a 400wh rack one on our Raleigh Motus of similar vintage with a 500wh on from Merlin.
All went fine, delivery was quick and efficient and it just fitted.
6,723
