Brake hose
djf123
Jul 17, 2025
Hi would anyone know
Which replacement brake hose would I buy for a 2019 crossbar torque, would a Shimano one suffice and if so which model.
Dave f
Waspy
553
223
Dave f
Do you mean the Wisper 905 Torque Crossbar?
This bike came with cable operated disk brakes. Has yours been upgraded to hydraulic brakes? If so do you know which brakes?
3,978
Dave f
I think you need to explain what's going on and which brakes you have. What happened? Don't tell me it was "the dog ate my brakes" again, or was it the rabbit?
Raboa
901
318
53
If cable operated brakes then try Jagwire compressionless housing or Shimano compressionless brake housing.
matthewslack
2,493
1,630
Either the caliper or the lever or both will have the maker's name, and most hoses will have too. Use that make. If completely unidentifiable then take the old hose and fitting to a bike shop who should be able to tell you what you need.
If reduced to guesswork, I'd guess Shimano first, and unless it is a 4 piston brake it will likely be the BH59.
