Chain keeps coming off ,question ?
Hixyhicks
151
10
55
My chain keeps coming of when im in the smallest gear of my cassette.The chainline isnt great .Can i move the smallest gog half way up my cassette ? which will improve the chain line.Im using a lekkie on the front .
Cheers
Scruffydroid
53
20
Is this a conversion, or shop bought? Usually the former requires a complete reindex and stop limit adjustment. If it is shop bought, then take it back for a service. If you want to try yourself, then see below YouTube.
Usually with a crank motor, the chaingear wears relatively quickly and needs replacement of the chain, and cassette. With a rear hub motor, the chaingear lasts a long time.
Check that your rear derailleur is correctly indexed / adjusted. If it is slipping off into the gap between the smallest rear cog and the chainstays, you need the limit stops adjusted - If it isn't changing one gear at a time per single click of the shifter, it also needs reindexing.
Hixyhicks
151
10
55
Hixyhicks
151
10
55
Everything is fairly new ,half of me is thinking about going single speed .
8,230
I would look at the derailleur stops first and see if a adjustment can help.
8,230
That means nothing if the stops adjustment aren't correct. I bought a new bike form Evans 9 years ago and the first thing I had to do was adjust the derailleur stops adjustment simply because they weren't set up correctly, also a derailleur could also be out of align or the hanger bent.
Related Articles
