In my quest to constantly find creative an low-cost but effective solutions to common problems, I offer this,
If you look at the "Bike Computer" thread, you can see that you can buy a cheapo bike computer for £2.04 from Ebay.
You can cut off the sensor (reed switch) and use it as a brake switch if you don't already have one - like when you've installed a kit, but didn't want to change your brake levers to the Chinese switched ones.
To make such a brake switch you fix the sensor to an exposed part of the inner cable (like along the cross-bar) with a couple of zip-ties and and then fix a small magnet to the frame with a bit of gutter sealant or whatever and space them so that the sensor moves over or nearer to the magnet when you operate the brake. If you have a steel frame, you only have to put the magnet on the frame, where it'll stay due to magnetism. This makes a really good brake switch. However, no good for hydraulic brakes, but you can still fix the sensor to the handlebar grip and mount the magnet on the back-side of the lever so that the magnet moves to the sensor when you operate the brake. You can cut away a bit of the grip to make the sensor fit nicely on the handlebar. Whichever method you use, you'll probably have to cut the magnet out of its plastic housing.
