Even understanding what im asking from the picture and my description will be impressive! Il try my best...
I have some lightweight trunking, its wide enough for 5 18650s and im going to make a hollow triangle from it and frame mount battery and controler, the trunking has a handy lip to so will then just gasket sealer and pot rivot the ally sides on, prob is im strugling with assemblimg the battery, this is a cardboard cut out of the rough areas im working with
So if you have any idea from that photo where im at... Its a 13s 7p and Conecting bank 4 to bank 5 is my dilema, can i just use 3" long nicol strip to run across? Really dont want to solder unless i have to.
Ignore the 35 cells in the pic should be (42)
Left hand block 5 deep 10 high
Right hand block 5 deep 8 high
Il have a couple of cells to fit in somewhere also prob under the controller
So one row 5 deep 10 high and another row 5 deep 8 high, how would you tally up 91 cells?
Ps fox thing was an accident but then reading this far earns you a laugh!
