Cyclamatic power plus battery charger
Acestu
Aug 26, 2020
Hi,
Could somebody please tell what the exact voltage and amperage is of the charger for the 24 volt Cyclamatic Power plus please As my sister has lost hers.
Stuart
3,994
It's not critical. The original was around 2 amps, which would be ideal considering time to charge and stress on battery, but anything between 1 amp and 3 amps would be OK.
When you get your new charger, it's always worth checking that the pins are polarised the right way round with a meter. It's only the outer two pins that are used. The third, sort of central, is not connected to anything.
