Cycle Analyst v2.1
daniel.weck
1,230
FYI, the updated manual is now available:
http://ebikes.ca/drainbrain/CycleAnalyst_Manual_Vers21.pdf
We've finally finished the complete Cycle Analyst Version 2.1 User Manual. It includes a thorough explanation of the many more advanced features that were added in this firmware update, such as serial data logging, on-the-fly current and speed limiting, using the CA as a 'current throttle', and additional details on the wiring and circuitry.
www.ebikes.ca Homepage of the revolution
daniel.weck
1,230
Nice to see the Cycle Analyst used in large applications. This is a powerful 72V motorbike (4mn into the video):
YouTube - 14 Electric Motorcycle "Jozzbike"
I love how the 220V charger is placed into the frame, with its long extension lead :p
These cylindrical LifePo4 3.3V 10Ah cells look good too, but the prismatic/pouch cells are a lot more convenient on a bicycle (e.g. and a battery like the Li Ping comes with a good built-in BMS for balancing and for protecting against over-(dis)charging).
It seems that A123 and their high discharge rate is definitely the way to go with lower capacities (<= 5Ah). I can't wait to see Simon's DIY work :)
emissions-free
176
Shanghai
Dan it's now quite common to get these 10Ah cells. They are typically 38mm by 120mm if I remember correctly. They also can come with screw terminals (but overall length increases to about 145mm I believe) so no soldering or spot welding is required ;) Haven't seen anything smaller than the 10Ah cell with screw terminals though.
I'm gonna pull apart a 36V 9Ah pack I've got here and will try to take some piccies of what I do with it. It's already got a BMS, so it's just a case of reasembling it into the form that I require.
Do you think people would like the option of buying cells and BMS seperately so that they can assemble the pack as they require?
daniel.weck
1,230
Well, there is always the option of using a proper balancing charger, which I suppose would cost at least 40 GBP (I just recently stumbled upon the Turnigy 6 cells).
The BMS on my Li Ping battery (36V 10Ah) is a pretty small circuit board with a good reputation as far as reliability is concerned. It's also nice to have the choice between a cheap lightweight charger or a more powerful one for fast charging (one at home, the other one at work).
That being said, using a small pack of A123 cells (<= 5Ah) without a BMS is not so much an issue when a Cycle Analyst (or comparable device) takes care of protecting against over-discharge and other potentially damaging circumstances (voltage drop, excessive current draw, etc.).
At any rate, this is not a new topic and many people (including members on this forum) have lived through the joys of DIY battery packs. I have no such experience so I'm all ears :D
Cheers, Dan
daniel.weck
1,230
