Cyclone
3,989
In principle, you can use any controller that gives the same power. You don't have to use one like you already have.
From the code, yours is from Santrol , which are OEM only. It's 24v and 13 amps. If you get an alternative one, you might need to swap over a connector or two and you need to buy a matching LCD for it. Prices are from £30 to £80 depending what you want.
If you're not sure about this, show a picture of all the wires and connectors attached to your controller.
What is the problem you're trying to solve? Maybe you don't need a new controller.
