Dave the rave
Baz the balloon man
432
20
Dave the Rave .
Did you go Sunrise , Energy , Raindance , Ministry of Sound back at the beginning ?
Is this what you are looking for pls see attached.
The Motor was water damaged and seized PCB looks ok not sure if it will work for you.
Seems like a lot of work to me rather than buy a later SH motor rim and new extension wire to get over the male female plug difference .
Pre 2019 Crossfire .
The LCD holder , switch and clamp also from an older Crossfire walk assist was stuck on so I just sold the screen some time ago.
Personally after stripping this motor and getting the longer Axel out I am going to use a later motor on the guys bike squeezing in the rear drop out and then adjusting the derailleur to the cassette once the brake has lined up .
Clamp or pull in with threaded bar a lot less agro than stripping a motor down for me any way.
