Disc brake issues
6,728
they do them for race bikes but not seen any for a mtb
cyclebuddy
1,677
784
Beds & Norfolk
Can you get dual piston cable brakes? The main issue with my cable operated disc brakes is that they only operate on the outer brake pad so it basically pushes the disc against the inside brake pad.
Although it works, it's not an ideal system as the disc gets warped every time you apply the brake unless you stop them up very carefully.
I've seen dual piston cable on Ali.
Why don't you try these? They're a direct swap dual piston hydraulic caliper like the TRP ones Woosh suggested in post #2, but are only £20-24 a pair.
They're not full-monty Hydraulics, but better than the usual cheapy single piston cable caliper, and use your existing levers/cables so retain the motor cut-out. I'd think they'd be perfect for your MiRider, as they are for my D11 folder.
lightning
272
77
Thank you l will definitely have a look at them.
My post should read
".....unless you SET them up really carefully" not STOP them up really carefully !!
