Does anyone experienced a lcd lag?
Zazarazas
Oct 1, 2024
Lcd refreshes really slow, like every second or so. i was wondering how could it be fixed? thanks
thelarkbox
1,666
517
oxon
hi n welcome, Thats a new one ;) -to me at least... What info needs a faster update? could you take a short vid and describe whats bugging you?
Might just be you have too high expectations and thats just the way it is? or your display/system has an issue not encountered frequently?
2,852
For any parameters that change slowly the lag is irrelevant.
For any parameters that change quicker there is probably variability in the parameter and noise in the measurement. If the ldc refreshed faster it would probably be changing too fast and make it difficult to read.
thelarkbox
1,666
517
oxon
Gotcha - the delay is in response to user input when using the menu system..
Unless you can find the same display running faster.. I would suggest that yes thats about it. the lil processor in the display unit is struggling painting the response screens in the setting menus, they use the cheapest ic they can for the job or it could be cheap slow memory chips that hold the bitmaps?? certainly not in the same class as an intel 17 etc..
Not something you should be doing when riding the bike or frequently (more than once for initial setup) so its deemed good enough..
EDIT - an afterthought, extra delays could be introduced by less than perfect connections between the controller box and display requiring repeated resending of info before a clean acknowledgement (if required?) is provided. so check wires/connections (talk about clutching straws....)
As long as settings changes you make take - all is good.
