Education help needed
robert1976
144
49
I've spent a good few hrs now trying to get my head round this controller I've had some help from a great member on here. I've sussed a few bits. But others in lost on.
On off button.
+ And - buttons.
So far I have learnt
Pressing the + button and holding turns on front light.
Pressing and holding - button shows a walk icon but doesn't change nothing.
Holding power button turns on and off.
Now holding +&- at same time takes me into menu and or out off menu.
Looking in general I found guides.
Some seems to tie up others open up questions.
P01 = LCD brightness. All good
PO2 = mph or kph. All good
P03 = volts 24 36 48. All good
P04 = sleep timer. All good
P05 = I'm not understanding totally.
0= throttle disconnected
1= motor will start to assist from peddles or throttle if other settings allow.
2= throttle only not peddle assist. (Not EAPC)
P06 is apparently wheel size. Now this I would kinda agree, but if I alter this it alters my max speed on Speedo In line but feels no different. ???? Ps my wheels are 14inch
So if I say the 5 inches it limits to 5mph, if I say it's 50inch it limits to 52mpg. 14 is 15.4mpg
P07 = magnet speed test. NOW I HAVE NO IDEA ON THIS, WHAT DOES IT MEAN AND MAY HAVE ADJUSTED IT
P08 = Speed limiter apparently. It goes from 0-100 choices but does not seem to make a difference.
P09 = drive IE ? Whether O auto or 1 kick. Please explain???
P10 = 0 no throttle. 1 throttle only (none eapc legal) 2 throttle assist. (Eapc Legal or not?
P11 = 1 to 24 sensitivity I believe with 24 being higher sensitivity. Is this to peddles ?
P12 = 1 to 5 power assist intensity range. Is 5 high and controls acceleration aggressiveness ?
P13 = magnets ??? Not touched.
P14 = amps. Pretty straight forward
P15 = no idea no adjustment available
P16 = odo readying and reset ability.
Really hoping someone in Ss13 Ss14 ss15 or ss16 could personally help me but in mean time I can learn via online.
Help
3,994
P05 is 0 for pedal assist only, 1 throttle only, 2 both working.
P07 is probably the number of magnets in the speed sensor - normally 1 or 6.
P10 is probably 0 throttle disables and 1 or 2 6km/h and full range throttle.
P11 is exactly what it says, but I guess it's how many PAS pulses before it gives power.
P12 is how much power you get on start of pedalling.
P13 might be speed sensor magnets.
Speed limit only goes as far as the motor's own speed limit, like if I said you are allowed to run at 100mph. Permission isn't the same as ability.
robert1976
144
49
P5 2 = both throttle and peddle activate motor. Is this setting EAPC legal on a post 01 Jan 2016 manufactured bike. Cheers
