Woosh EFNEO GTRO
richardg6paj
79
16
72
Messingham
Anyone got one of these? Thinking about the problems fitting one to a Woosh Rio Fat Bike. Only problem I can see so far
is the crank sensor and where to locate the gear changer.
Andy-Mat
2,214
564
78
Could you please post a photo, or a better description, or both?
Andy
17,342
You don't need to change the bottom bracket - the axle on the Rio FB is long enough for the Efneo.
You will need to replace the current right side pedal sensor with a left side pedal sensor.
richardg6paj
79
16
72
Messingham
Thanks Mr. Woosh, have you fitted one of these? I'm thinking the twist grip would be easier to fit than the trigger type. Assuming that the handle bar is the required diameter. Although expensive, It looks like a worthwhile addition. Any advice would be welcome.
