Electification
Jack01
7
Just ordered a Woosh Frog kit for brompton ro ease my ancient legs. Looking dforward to seeing what difference it makes to hills and headwinsds.
StuartsProjects
1,858
1,040
I have used two Electric Bromptons, both have made a signicant differance to ease of peddling, the benefit is most noticable on the hills.
You will also likely find you dont use the gears much at all.
StuartsProjects
1,858
1,040
And a tip, I have a Brompton with the battery on the front bag block as well.
If you have a rear rack on the Brompton with wheels on, you can fold the Brompton up and push it around inside shops like a shopping trolley, safer than leaving it locked up outside.
An extension bar that costs as much as £4 and fitted to the right rear wheel on the rack should help reduce the risk of the folded Brompton from tipping over.
54427
Reactions: Oldie
jimriley
617
412
The frog battery I've seen has a red light on it for when mounted on the rear, useless for the front. @Woosh Can there be a choice, a replacement white lens appropriate for the front?
17,320
I don't have it, sorry.
