Hi all,
I was given a non working electric minimoto and got it running with a trio of 6V batteries to replace the completely dead original 18V job.
This worked great...............until my daughter rode it about 20cm and dropped it. Now it just runs, only disconnecting the battery, main fuse or motor stop it.
I’m guessing the ESC is damaged but getting hold of the exact one is pretty impossible in this country so I’ve been looking for simple replacements. Any ideas? I’m no electrical guru so am a bit lost beyond needing an 18Vish brushed ESC, but they all come with different wiring to the existing one, can anyone help with how to get it running again?
I've attached a photo of the current ESC.
The red circle covers the power and motor connectors, black/red and blue/brown respectively.
The blue circle covers the throttle and brake connector. There is no brake light so I guess it overrides the throttle. Brown/green/red is the throttle, orange/black is the brake.
The black circle is the charger connection
The green circle cover the key/ignition connector although the bike loom only has one wire.
There is a main fuse on the bike that is wired into the motor cables so has nothing to do with the esc.
Thank in advance!
Matt
Thank in advance!
Matt
