Fine Steed
8,750
What a bloody mess !!! Ok if you want to ride a 50kg bike, it must handle like three sacks of spuds on a soggy afternoon.
I count four silverfish's, how many more lurking in the panniers.
At the other end the Royal Enfield looks pretty.
egroover
1,094
655
57
UK
jeez, looks like the owner covered it in glue and ram raided aliexpress...what a mess
2,831
Saw this splendid self build parked at my local Sainsbury's.
What makes you think it's a self build; I think it's from one of those 'style over substance' boutique manufacturers.
3,359
In addition to the four silverfishes - in the second photo, that black oblong with a red light on the end, under the basket camouflage looks to me like a rear rack battery, mounted sideways on the front rack. Are those two Zefal bottle holders bolted to the handlebars, for bottle batteries? I'm bewildered by the number of displays - voltage and/or heat monitoring plus kit displays? Plus whatever else. So many switches! Are some for disengaging and engaging batteries? I like that he has connected rear flashing indicator lights, via a waterproof 12V aluminium housed buck converter (pic 1, between basket and handlebar)- it's the same model I was thinking of buying to possibly power indicators. That looks like yet another battery connector hanging loose out the back, near the rear wheel in the first photo - so there may well be more batteries in the trunk and/or pannier bags. Maybe he's a Mad Max type, prepared for the oil apocalypse? His red rear light near the wheel, is on the wrong side.
6,722
frames have waight limits for a reason so it is when not if that thing will snap in half.
3,359
About 25kg to 30kg (or more) in batteries? Maybe it's escaped from a comedy film set? Is it normal for a fire extinguisher to be kept next to the door (third pic), was someone nervous? It's the maddest looking self-build I've seen on this forum, and one which appears to work. But there was that other top heavy monstrosity, covered in aluminium boxes for no apparent reason...
8,750
I like egroovers reply, ' ram raided aliexpress' priceless.
Reactions: guerney
