Hi there
So I got this Cute 350W front hub motor from BMSbattery. Very happy with the service and the communication with Mr. Jack Xie. I'm building my wheel now and I'll be posting my impressions of the motor in due time.
However there are various issues with the hub itself:
For starters its 10mm axle would not fit into my 9mm dropouts (an Orange F8 fork); I had to grind it (the axle) with a dremel tool.
The fork also has non-dropout lips on its outer sides, so the non-turn washers had to be filed into the appropriate shape to fit in, too.
Then the disc brake fitting holes. Screwing the bolts all the way in locks the hub, as they end up pushing the inner body/rotor of the electromagnet.
Filing the bolds to circumvent this, fixes the rotor at a position outside the adjustment range of my brake caliper (aren't these standard distances?!?). [spacing the caliper is not an option as I plan to switch wheels frequently on this bike].
Putting a spacer between the rotor and the hub body fixes this issue, but then I noticed this:
The profile of the non-drive side end of the hub, which is supposed to press on the dropouts, seems to be quite narrow (see attached image). So, there is a regular washer supplied in the package and I'm thinking whether it is intended to be used there (it's somewhat visible in the image, too). If the spacer is used, however, then the rotor needs 3 spacers (in each of its 6 bolts) in order to achieve alignment with the caliper. I don't feel this is very safe.
So, you kind people, do you use spacers to fit your hubs?
do you think the hub end I show in the picture is too narrow or is it ok?
Any input will be highly appreciated.
