Hi.Wheel of ground runs fine.wheel on ground blows fuse.could the ratio have anything to with this,changed from belt drive to chain drive,gone from 11/1 to 3.4 /1 ratio.Motor RPM 4450,is the RPM to high. HELP.John
Is the fuse between the battery and controller (normal) or between the controller and motor (not normal)?Hi.Wheel of ground runs fine.wheel on ground blows fuse.could the ratio have anything to with this,changed from belt drive to chain drive,gone from 11/1 to 3.4 /1 ratio.Motor RPM 4450,is the RPM to high. HELP.John
Perhaps your controller is not limiting current enough. Do you know what the controller model is and what the current limit is?Hi. John, the fuse is between battery & controller.the fuse blows straight away when you twist the throttle. john
Sounds like the controller is pulling more amps than your fuse can take in that case. Mind you, you shouldn't need 30 amps to get the bike going.Hi.The controller is a 4QD Uni 24/8 OUTPUT CURRENT 115 AMPS. It`s only blowing fuses when loaded.John
