C CarpeDiem Guest Feb 3, 2023 #1 Hallo. Weet iemand hoe ik de gashendel kan uitschakelen op het Kunteng LCD3 display??
saneagle Esteemed Pedelecer Oct 10, 2010 9,004 4,030 Telford Feb 3, 2023 #2 Downloads--Suzhou Kunteng Electronics Co.,Ltd--Suzhou Kunteng Electronics Co.,Ltd Suzhou Kunteng Electronics Co.,Ltd www.szktdz.com P4 and C4 parameters control how the throttle works. If you want to stop the throttle function, disconnect its connector.
Nealh Esteemed Pedelecer Aug 7, 2014 21,542 8,790 62 West Sx RH Feb 3, 2023 #3 If it is a case of legality in Germany then simply disconnect and remove the throttle.
W WheezyRider Esteemed Pedelecer Apr 20, 2020 1,690 938 Feb 4, 2023 #5 CarpeDiem said: Hallo. Weet iemand hoe ik de gashendel kan uitschakelen op het Kunteng LCD3 display?? Click to expand... Translate: Hello. Does anyone know how to turn off the throttle on the Kunteng LCD3 display??
Nealh Esteemed Pedelecer Aug 7, 2014 21,542 8,790 62 West Sx RH Feb 4, 2023 #6 One can't switch it off, only change how it operates . As has been said, disconnect it if operation isn't required.
