Hi,
I am looking for some info regarding the Gazelle Innergy 36V Battery outputs.
I have recently bought a VGC but non-working Gazelle Innergy. I knew the battery was faulty but when I took it apard the wires on the BMS had been cut off & half the cells were missing. Using the battery outlet socket I wired up a generic 36V battery which has powered up the LCD okay but the bike still does not work as it should. The battery plug has a 3rd (white) wire from the battery which I believe gives the LCD the battery voltage signal and my known full battery is currently shown as empty on the LCD. Also I found a user manual that says no power will go to the motor when the battery is empty (although it will still power the LCD & headlight for a time).
There are 3 wires in the battery plug - Red (pos) Black (neg) & white. Logically the white wire from the battery will be a 36V battery voltage signal to the LCD, but I am loath to just piggy back the battery +ve in case the voltage has been reduced somewhat by the BMS & I end up damaging/frying the LCD.
My question therefore is can anyone please advise what voltage is carried by the white wire from the Innergy 36V battery plug ?
Many thanks in advance
