Giant Road e+1 newbie....
Martin Shaw
15
59
Yorkshire
Hi...i bought an e+1 to use instead of the car when ever possible but finding the 15mph thing a bind.I bought the blackped+ dongle but got error messages after fitting so removed it.Does Anyone have experiences using the Speedbox 2 unit on a Giant Yamaha bike and is there a supplier in the UK.....
chris_n
801
471
63
Niedeau, Austria
Just fit a magnet on the end of the pedal and turn the speed sensor round, no more speed limit. The speedo will not work correctly but if that is a problem just fit a wired (not wireless, too much interference) cycle computer or use a smartphone with a gps speedo app. All a whole lot cheaper than a dongle.
Trevormonty
1,135
564
18
NZ
It works on Shimano Steps for 5 minutes then error14, ie "caught you tampering". To clear put things back to original and ride with err14 displayed.
Heard same for Bosch.
With newer Bosch and Shimano drives going for magnets on disc brake, tampering is going to become harder.
chris_n
801
471
63
Niedeau, Austria
Will a neodymium magnet stick to the aluminium crank or pedal axle....?
I used a standard speedo magnet with a drop of araldite on the pedal axle. The araldite is probably not required but I do ride off road in the Alps so a little extra insurance. I also fitted a second neoprene chainstay protector to the non driven side of the bike which hides the sensor nicely.
The pedal shaft is normally steel, so a magnet will stick to it.
Martin Shaw
15
59
Yorkshire
Neoprene chainstay sleeve!....great idea
Martin Shaw
15
59
Yorkshire
I'm wondering whether it will work...maybe Giant/Yamaha have updated the software to detect tampering on the 2017 model as opposed to the 2016 road-e....( Like the bosch drives)
6,709
Martin Shaw
15
59
Yorkshire
id be surprised if it did work tbh but you never know till you try so do it now n hurry up and test it ;)
https://www.youtube.com/channel/UCj2JXQ8nVoyOQ98t8ZDUldg
msg him on there see if he can help you out with the dongle ;)
Going to have a bash tomorrow...going to Maplins for some magnets...tbh i'm going off the dongle idea.After the blackped+ dongle errored my bike i was glad it didn't leave the bike cabbaged
6,709
there are 100s of error msgs so it is ok to try the dongles but as this bike is giants system gave the link to the guys you tube page that makes them.
a bad ass dongle will work like i have just might need a adaptor as goes over the sensor and can be removed in seconds and bike set back to normall.
https://www.badassebikes.com/en/badass-box/yamaha/typ3-4-yamaha/a-116/
you need bigger better brake rotors otherwise you will cook them n you dont want that.
Martin Shaw
15
59
Yorkshire
Interesting... I think i'll look at that if this fails.Won' t be going mad on speed anyway brakes-wise.I just want to be able to ride at 20-25 on the road.No drama
6,709
ur bike is only 1.8kg lighter than my fs mtb mind and dont take much to make them in to rings of fire just when that happens is you cook the pads and warp the rotors.
you want some 2 part rotors to help remove the heat i have 203mm front and back like a dh bike.
Martin Shaw
15
59
Yorkshire
On closer inspection the speed sensor screw is a small torx but with a tamperproof peg in the middle so will not take a standard torx driver or tool... Is this tool available...?
