Grease for a Bosch CX Motor
bikey850
97
15
125
UK
Hello,
Any particular grease needed for a Bosch CX motor? Is it special Bosch stuff or just regular grease be okay?
Just looking to better lubricate (preventative measure) to eliminate any future creaks etc.
Many thanks in advance,
The Bear
517
179
53
South Yorks
Are there any DIY guides on here for accessing the motor, greasing and service work required?
6,717
if you or a dealer opens the motor it voids the 2 year warranty so best to leave it alone until it runs out.
  • Useful
Reactions: The Bear
Trevormonty
1,135
564
18
NZ
Hello,
About you can do is avoid spraying water into bearings when cleaning bike. Service drive side bearing seal regularly. More MTBing you do more it needs servicing.
See attached parts list for grease and spare seals. Will also need spider tool to remove chainring guard also in list. Watch video
mike killay
3,012
1,629
Pity that he did not quote the torque tightening figures for the lock ring and crank.
To me he hardly tightened them at all.
The Bear
517
179
53
South Yorks
My crank bolt fell out the other day whilst cycling, resulting in my pedal falling off. The new bolt needs torquing to 43 - 48Nm. I shall be applying a drop of thread lock to mine as I'm checking them after each ride and they are both coming loose.
