Halfords Coyote connect sensor
Kevbirch
Apr 16, 2021
Hi - I lost power this morning and looking closer it looks like my sensor has cracked - possibly when my chain came off recently.
Looking around there looks to be several out there ranging from £4 to £40!
Is there a particular type I should buy or is the chesp and cheerful one a good option?
3,994
The cheapest one will probably work the best. If it's only the magnet disc that's broken, that's the only bit you need to replace. They come as a matched pair, but just put the sensor asside and fit the disc as long as you can find one with the same size disc. Avoid 12 magnet ones because of compatibility issues.
