HEADSTOCK LOOSE !
KEN OPENSHAW
54
12
82
Hi All
Well at last got my ebike a used 2016 Wisper 905 Torque 200 + miles !
It came in a box and the headstock is loose how do I tighten it ?
16,466
Wisper Bikes
6,230
2,197
68
Sevenoaks Kent
Hi Ken,
Try this...
1. Loosen the two bolts on the stem.
2. Remove the rubber bung on the top of the stem.
3. Tighten the bolt found under the bung.
4. Hold on the front brake and hold the front wheel between your knees, when you turn the handlebars left and right there should be no movement in the handle bars.
5. Re-tighten the two bolts on the stem.
If you still have problems give us a call.
KEN OPENSHAW
54
12
82
Thanks David....the trouble was that the Allen bolt had been taken out and had got in the folds of the box....found it and followed your instructions......sorted thank you
But no rubber bung !
Ken
Wisper Bikes
6,230
2,197
68
Sevenoaks Kent
Ken
Hi Ken, please let me have your address and I’ll send you a new one.
All the best, David
KEN OPENSHAW
54
12
82
Hi Ken,
Try this...
All the best, DavidView attachment 26776 View attachment 26777
All the best, David
Thank you David
The Bungalow
Pentewan sands
At Austell
Pl266BT
