Hello!
I write this post here because info@heinzmann.de does not respond to my e-mails.
I want to upgrade my bike to electric assistance.
I have a one-geared bike with coaster (foot) brake on the rear wheel.
Hence I am interested in a hub motor for the front wheel.
I have considered buying a
Pedelec Standard Motor 26" FrontWheel A 24 V 21,5 250 W 10,5 33 A 38
870-00-751-4906 341,00 Eur
This is the only motor I found in the table
Estelle – Electrobikes – Bicycles with Electric Motor – Auxiliary Drive – Power Assist Drive
that is meant for something like bicycle, not "vehicle" and meets the requirements 24V, 250W. But as the law in my country does not require pedalling while the motor is working (there is only 250W power limit), I might buy something like
External Control NiCd 24V/33A for E-Bike 215,00 Eur
and forget about the pedalling sensor. (Though the motor is labeled "Pedelec standard motor".) Is the above technically correct?
(Of course, some twist grip "Twist Grip (180 cm) 59,00 Eur" or alike is
also needed.)
Another question is, how is the wheel diameter really limited? The above "Pedelec Standard Motor" is by specification meant for 26" wheel, but my wheel is 28" standard. Does anyone know whether the "26 FrontWheel A" in the above specification is EXACT or MINIMUM diameter of the wheel where the motor is to be fitted? (And if exact, then why should it not work with a 28" rim?)
I dislike the 36V motors since I am looking for batteries of higher
capacitance (some 30 A*hour or so) elsewhere and such batteries are
mostly 12V standard. Thus three such (heavier) batteries would be
overkill, two is hopefully alright. (I am going to mount the batteries
on the rear, so the 100 kg limit on the front hub motor axis should not
be exceeded.)
I hope someone who has experience with Heinzmann could help me.
also needed.)
be exceeded.)
