Help locating FreeGo Controller
Macster58
38
Hi everyone and good day to all. I am Desperately trying to find a freego hawk electric bike controller (36v 15A for 250 watt hub motor).
Picture of my ebike and the controller sticker. Provided for reference.
If anyone happens to have either a
FreeGo Hawk Step Through Electric Bicycle or a FreeGo Hawk Crossbar Ebike which is no longer working or just being scrapped for whatever reason I am destfor the controller and I will be happy to pay a fair price for it. There are some other freego ebikes that may have the controller I’m looking for and they are one of these:
FreeGo Wren
Or
FreeGo Regency
Or
FreeGo Folding ebike
Please feel free to message me via the site or send me a text message to 07742937639. Thank you.
3,994
The Freego one isn't that good, and if you can find one, it'll be expensive. You can replace it with a different one, which will be better if you don't mind doing a bit of soldering.
8,790
You won't get Luan yang unless a spare appears for sale or possibly ebikes direct have one. Replacement with another readily available make and display is best and will likely be as cheap to do.
Macster58
38
I totally get that it will be hard to locate and in the meantime I have bought one set from Aliexpress i.e controller and display. The controller had all the connectors I need for my bike except for 1 wire which is the light. The controller only has 1 breaking light & 1 light. So I will have to run my front and back light from the 1 light output. The controller I bought was only cheap (£30.00) but hopefully it will work as it is the same spec as my original one which is 36v 15A for a 250w hub. Picture is of my new set that should be here next week.
3,994
On eBay item number 254746517869 from Atman-Freego seller. Genuine Freego agent.
Freego used many different controllers and wiring. You have to get the exact replacement if you want plug-and-play, otherwise, it's better to fit a KT or Brainpower one, which give you a lot more features and options.
Macster58
38
I have managed to get my new controller and display working. It a China made cheap one for £30. I had to modify the wiring loom by way of totally removing out of the frame then cutting some wires and doing some re-soldering but eventually I managed to get both the brakes to work i.e the motor cuts out. the Throttle works and the throttle on and off works. the lights work but unfortunately they remain on once I turn the keys on the batter but I was thinking worst-case scenario I could just put an on and off switch on the handle bars between the lines and add it to the handlebar. I managed to get there in the pas sensor working no problem at all also. .But for some unknown reason the brake light doesn’t work I’ve tested the connectors with my multimeter and there doesn’t seem to be any power going through to the brake light connector which makes me think that for some unknown reason that’s faulty what do you think?
