Hi Guys
Got this kit on order - BAFANG BPM 36V500W REAR DRIVING BIKE CONVERSION KIT
Notice it has the following connections -
Motor - obvious
Brake - obvious
Motor hall sensor- Is this required what is its purpose ?
1+1 pedal assisted wire - What is this ?
Throttle wire - obvious
3 speed switch kit - ????
speed limit wire - presume just restricts to 15mph ?
cruise wire - when operated keeps motor/voltage as set ?
What is ABSOLUTELY needed (motor,throttle -obvious) and what are the other s for and does anyone have pics/advice of where how to fix them ??
Here is a pic of the controller -
I plan on using a standard MTB with discs. Have the batteries running at 44.4v 15ah lipo.
Cheers
Motor - obvious
Brake - obvious
Cheers
