Help needed to find a part!
8,746
Is it a Polly case battery ?
Andy-Mat
2,214
564
78
What’s a poly case battery?
This is the batteryView attachment 36705View attachment 36706
Could even be a battery from a Stark Bike.
Look here, they sell most parts, assuming it is the same spacing/size:-
Just guessing.
I might be able to be more definite if you post the actual measurements on a drawing or photo.
Andy
Reactions: Muddyfox
3,994
This looks like the battery case. halfway down the page, it shows the connector. Normally, the connector would come with the case as a set. It might be worth asking them just to make sure. Their English will be bad, so keep it simple. I doubt that you will get the connector on its own anywhere. It detatches from the cover that you're holding.
This one has the whole set, including the cover, but you have to buy the battery. Do you need a spare battery and charger?
8,746
Something similar to this, though may not 100% be the correct item.
Darranna
73
15
South Essex
Just guessing.
Andy
Technical drawing is not my forte, but if I’ve missed anything or you need me confirm let me know.367073670836709
Reactions: Andy-Mat
Darranna
73
15
South Essex
perfect thank you for your help.
8,746
Andy-Mat
2,214
564
78
Technical drawing is not my forte, but if I’ve missed anything or you need me confirm let me know.View attachment 36707View attachment 36708View attachment 36709
Thats technical enough.
The bad news is that it does not appear to be the same battery or battery plug.
The good news is that you may have some sort of e-bike standard pinning, as the pins on my bike are exactly the same number and same distance apart, but at an angle to the vertical.
I hope this helps in some way.
Regards
Andy
Only an LBS might be able to help if its a fairly standard type
