Hi All
Thought to post this before I go at it as its quite common damage on e bikes .
Bought in the Bird bike to sell as spares the motor wire was damaged from a fall finally got round to doing a repair .
Sadly not possible to do a join at the end of the Axel because the small green wire is broken in side the axel.
Never done this before .
I may be able to loosen the PCB and get enough of the green wire to solder to heat shrink ECT not sure if it will gently pull through.
Prefer to try and fit a new cable and plug I think just to gently prise off the plastic collar ? To free the cable
Can any one advise on this before I damage it .
U tube video would help .
I think we should have master class videos from the professionals on here if you guys are up for it . It would be a credit to this site in my opinion.
And very helpful to owners , DIY and traders like me who are starting out.
I want to sell the motor and rim when done .
Very clean and dry compared to Suntours motors which have done around 1000 odd miles .
Any other advise ie where and which type of grease to use when assembling it would be welcome for a professional standard repair .
Cheers
Baz
Cheers
Baz
