September 11, 20196 yr Hi guys n girls. Dose anyone have any idea how these Panasonic 25.5 volt motors are restricted I'd been looking at the wires and it looks like the conrol box is inside the motor . I added a few photos. Big thanks n stay safe.
September 11, 20196 yr Author Am keen to find out what the spare connectors are for . I know it had a throttle but it was removed. Also there are 2x purple wires and 2x grey that are taped to the frame unconnected at one end . The bike gets used of road at work so not on road. I just really want to understand this thing and if possible remove the 15mph limit. Thanks for looking.
September 12, 20196 yr First place you need to look is Flecc's excellent Panasonic info site http://www.flecc.co.uk/p/panindex.html . One of the unused plugs (think it's the triple wire one) is for the walk assist button to plug into, which provides assistance at walking speed of up to 4mph.
September 12, 20196 yr Check out fleccs page, you can add a little more torque by change the drive sprocket to an 11 tooth, you can also add more speed by changing the sprocket on the rear wheel. The controller is inside the housing and is potted, you can add sodder to the busbar to boost the amps and thus torque further but I would be wary of doing that because it might overheat the components on the controller which is potted. If you do make any mods let us know how you get on.
September 12, 20196 yr Author First place you need to look is Flecc's excellent Panasonic info site http://www.flecc.co.uk/p/panindex.html . One of the unused plugs (think it's the triple wire one) is for the walk assist button to plug into, which provides assistance at walking speed of up to 4mph. Big thanks for the info . I'll check out the link. Has got me thinking!
September 12, 20196 yr Author Check out fleccs page, you can add a little more torque by change the drive sprocket to an 11 tooth, you can also add more speed by changing the sprocket on the rear wheel. The controller is inside the housing and is potted, you can add sodder to the busbar to boost the amps and thus torque further but I would be wary of doing that because it might overheat the components on the controller which is potted. If you do make any mods let us know how you get on. Big thanks I was hoping it was a quick snip ! I have All ready added a 500w hub motor on the front and between the the whole thing works great 2 wheel drive up to 15mph then just on the front hub with a throttle. I know the mid drive did have a throttle before . Am going to hook up the pas sensor soon to have both motors when peddling. Big thanks for your reply.stay safe. I love old girl . Big thanks for the reply.stay safe.
September 12, 20196 yr Ha ha, bet that flies up the hills. If you want yet more speed and power I recommend the 11 tooth mod, nice a simple to do, you might need extra chain links.
September 13, 20196 yr Author it dose ! Ha ha, bet that flies up the hills. If you want yet more speed and power I recommend the 11 tooth mod, nice a simple to do, you might need extra chain links. Thanks , where would I buy the 11 tooth sprocket from? Is it special to the motor? Big thanks.
September 13, 20196 yr Author First place you need to look is Flecc's excellent Panasonic info site http://www.flecc.co.uk/p/panindex.html . One of the unused plugs (think it's the triple wire one) is for the walk assist button to plug into, which provides assistance at walking speed of up to 4mph. Big thanks the links great the walk assist could be what they ment when they said it had a throttle before . Any idea on other? Thanks again.
September 13, 20196 yr it dose ! Thanks , where would I buy the 11 tooth sprocket from? Is it special to the motor? Big thanks. Yes it is. Still lots of them around as its a popular bike on the continent. https://www.ridewill.it/p/en/connex-3050502600-sprocket-1-2-x-3-32-11-teeth-increasingly-for-panasonic-e-bike-engine/121582/
September 14, 20196 yr Author Yes it is. Still lots of them around as its a popular bike on the continent. https://www.ridewill.it/p/en/connex-3050502600-sprocket-1-2-x-3-32-11-teeth-increasingly-for-panasonic-e-bike-engine/121582/ Awesome thanks for link!
