I’m new to this- advice appreciated
Hoofer
Oct 31, 2022
Hi everyone, I have a couple of Marin mountain bikes; a nail trail and an attack trail, both are about 20 years old and I would like to convert one of them to electric.
I would prefer to convert the full suspension attack trail with a motor on the bottom bracket but am not sure whether it would be compatible with a modern kit. I get the impression that a rear hub drive for the hard tail nail trail would be much cheaper and probably more straight forward.
Any advice would be greatly appreciated
2,835
Measure the bottom bracket width and post some photos; that will help people to give good advice.
If you have seriously steep hills or do quite technical mountain biking then a crank conversion will probably be best. Otherwise a rear hub should be quite adequate, and probably much cheaper and probably more straight forward as you say. You will also need to check the axle/rear dropout width. They tend to be a little higher today than 20 years ago; that might limit you choice of rear hub motor. I guess the frames are aluminium; you would need great care stretching them, probably best avoided.
jimriley
617
412
A bafang bbs01b in the hard tail would be great. I fitted on to my 2006 hybrid with 42t front cog, great on the tracks and trails around.
