Hi all,
This is what i understand about the function of pedal assistance,please correct me if i'm wrong. With power on and PAS engaged you should complete one turn of the pedal ie (one turn revolution) in order for the pedal assist to kick in and do it's job until you stop peddling then PAS is no longer required, in turn cuts off all power to the motor via the controller.
If this is correct, sometimes of late i notice that when i am just about to set off for a ride,then shortly afterwards i decide to use the pedal assist, i have to turn the pedal about three or four times before it starts to respond. What i normally find is that whenever this problem occurs i would quickly turn off the PAS then cut off all power supply, start up again,then it seems to be OK after that.
Therefore the question is,do you think something is at fault or is an electrical part on it's way out and requires replacement? Can anyone help ???????????????
Mountainsport. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
