is there a phone gps app that shows the route you have ridden
footpump
713
75
76
hi all
while there seems to be plenty off apps where you can plot a course,
I am not sure if there is anything that shows you the route you have ridden
I recently did a ride and used my garmin edge 200 uploaded ride to garmin dashboard and strava.
when I looked at my route only a couple ot the roads used were shown?
are there any apps that show the roads etc
davell
155
64
Doncaster
I’m sure there will be several. I use Komoot for planning but you can also record an unplanned route.
Sent from my iPad using Tapatalk
5,786
Oruxmaps
Sports Tracker is really good. I use it for every ride. You get the map, you can compare different rides, it shows calories, climbing and all sorts of other interesting info. I use the free version.
It has all sorts of advanced functions, but all i do is press start and stop each time I go for a ride, then I can see all the data. It's really simple to use.
https://www.sports-tracker.com/
rower
65
28
39
Berks and Bucks
Strava does do this - go through your training log, click on a ride, and the route you went on should be shown.
You can also use the third party service 'relive' to render a very nifty animation of where you've been.
footpump
713
75
76
thanks rower with strava I find it shows a route but does not seem to show all of the road names.
I installed sports tracker and set it to cycling and miles.
although I was on a bus it showed route taken, speed,miles etc.
what I am not sure about is can you reverse the route and follow it back to start point , can you save route to a pc
thanks all
thanks all
Yes. You sign up to an on-line account, then you can login and see all your records on the PC, where you can zoom in and see every detail. here's a screen-shot:
E-Wheels
227
103
hi all
BioLogic BikeBrain
BillyBoy88
76
78
Paphos Cyprus
I use Map my Ride free on Android, it integrates with Google Maps, I am well happy with it, you can also access the results via a web browser for more information.
