Anyone know where I can locate/purchase spare parts (throttle twist grip) for my IZIP Mountain Trailz electric bicycle??
Thanks for the reply, this is my first repair on an electric bicycle. I have spend the last 2 days on the tinternet going round in circles. I kinda thought they might be discontinued. I,ll look at your suggestion. I thought of 2 other solutions. 1. replace the twist grip throttle along with the electronic control box (approx. $90). 2. buy a 5 pin socket twist grip throttle, then try to work out the wiring for the LEDs and variable resistor. The throttle I have does not have a switch, just the battery LEDs and the twist resistor.Hi keith, welcome to the community.
It looks like your combined throttle/battery monitor/switch is discontinued but the link below offers a solution of two replacement parts the throttle and a separate switch. They appear to be in stock but being in the USA you will have to register to see if they will ship to the UK.
http://wildscooterparts.com/e-bike-parts/currie-ebike-parts/izip-parts/parts-currie-izip-mountain-trailz-al-mens.html
Thanks for the reply. I have ordered tools from US previously, I don't think the import charges are high for low value items.International Shipping
International orders ship just as fast as US orders, however, they may be subject to customs/dutys/taxes when they come into your country
Nice oneif they put free gift on it then you will not have to pay anything![]()
thanks for the reply. the bike may even be older. the friend who dropped them off to me brought the "his & her" IZIP mountain trailz AL. both have the same throttle, so I have to assume they were original to both bikes. i'll post a picture later on. the throttle don't resemble the ones on the link you sent.It sounds as if the throttle has been replaced before as the original one for this model had 7 wires going to it , 3 for the throttle, 2 for the battery indicator and 2 for the speed control selector push button (which switched between throttle twist and go TAG or pedal assist sensor PAS)
If you only want throttle then you do not need the switch but can permanently wire for throttle only, either open circuit or closed circuit, using the 2 wires mentioned above. I am afraid I don't know which combination you need as I have never seen your bike in the flesh.
A word of warning though the 2 wires for the battery indicator carry the full battery voltage if you were to inadvertently short them together you could seriously harm yourself and the wiring.
I suggest to post a picture here so that we can see what form of speed controls you have on your bike
Meanwhile here is a link to an izip manual:
http://ebike.research.pdx.edu/sites/default/files/Currie_IZIP_manual.pdf
Another older manual with wiring diagrams pages 43 to 48:
http://manuals.monsterscooterparts.com/recreational/iZip/iZipBikeViaLento.pdf
You have probably already found this.
Probably your only option unless you can get them to just sell the throttle - note it is for 24v bike, I assume that is what you have:
http://www.monsterscooterparts.com/currie-24-volt-5-pin-controller-throttle.html
