Kudos Cobra rear spokes.
Agoniuncle
Aug 15, 2019
Hi Peoples.
Can anyone tell me where I can replace spokes for the rear wheel of my Kudos Cobra?
Unfortunately the local bicycle shops do not have the correct spokes , because of the motor.
Is there any suggestions as to where to order them from. Alas Rally Design, who import the Kudos range were unable to help me!
Cheers,
Steve
8,755
Measure the spoke dia with a Vernier 2.3mm/13g spokes quite often used on OEM ebikes. You can and it is safe to use 2mm/14g spokes.
I use Sapim butted strong spokes a 14g spoke with a 13g J bend, these are a good replacement. To get the correct length you will need to remove a good spoke and measure from the inside of the J bend to the threaded end.
David Hazle
58
Uk
Alternatively, find a local wheel builder with a Phil Wood spoke cutter. Then if they don't have your size, they can make it in-house.
