larger sprocket = more speed ?
stu
30
64
Has anyone put a larger sprocket on to go faster when you have reached 15 mph, the gearing on my bike (e voyager ) is 7 gears and is not enough, when on the flat or going downhill there is no point in me peddling as my legs cant keep up with it,
You need a DNP rear free-wheel set with a 11T top gear, which you can get from Cyclezee. Alternatively, you can use a 52T/39T double chain-wheel, which you can find on Ebay. You might have to fit a longer BB for that to get the chain-wheel away from the frame,but not usually.
Arbol
391
25
This question is not really related to the original question of the post, but:
which kind of longer BB are there in the market? I ask this because I would like to put a 18650 battery in the frame, and one of the constraints is the angle of the triangle at the BB. Getting a few extra mm width would be handy there.
stu
30
64
Thanks for the advice, please forgive my ignorance but what is a bb.
Artstu
2,421
925
BB, bottom bracket, the spindle that connects the two pedal cranks together.
D C
1,145
578
Bottom bracket which the pedal cranks rotate around. d8veh's link has a picture:)
