Looking for ebike for rough gravel and road
Stella63
27
Hello. I've just joined. I did write a post earlier but it seems to have disappeared!
I'm looking for recommendations for an ebike that's comfortable on rough gravel off road trails (level, hilly trails mainly) but not too bad to use for general road use, locally in a hilly area.
8,746
Bike frame style ?
Stella63
27
I'm not sure. For the past few years I've hired various electric mountain bikes while on holiday. A specialized turbo levo (which I can't afford), a Trek Powerfly 5 and some kind of hybrid bike - don't know the make - which I didn't find stable on rough tracks. So I'm thinking I'd like full suspension for off road, but also something that rides reasonably well on road. I quite liked the Trek Powerfly 5 but it was very bouncy at the back on rough surfaces and difficult to get on and off.
Stella63
27
Just to add - there are so many more bikes since I first thought about getting one 4 or 5 years ago. It's a bit of a minefield.
8,746
Bouncy bikes are a night mare to ride as they sap your energy and waste it, for full sus one needs air suss front and rear where one cna pump them up to suit your weight to prevent the unnecessary bounce.
simonsays
15
I'm using a Cube Kathmandu for my commute on a mix of roads, cycle paths, grass, gravel and rutted chalk trail. 25 miles each way. It's a hardtail and was bumpy on the original road tyres despite a spring seatpost. I've just changed to tubeless tyres, run a lower tyre pressure and it's superb. Schwalbe G-one in 47mm width.
lightning
267
76
As above, hardtail or full suspension MTB if you plan to ride regularly on rough tracks.
However the good ones start at £2,000 or £3,000 for full suspension.
Stella63
27
Thanks - that's good to know changing tyres can help.
Stella63
27
Yes I was thinking full suspension for the comfort. Can you recommend any please?
simonsays
15
What about this?
The Kathmandu is quite a similar bike, made commuter-friendly for a bit more money. Slightly different frame. Adds lights, mudguards, rack etc. It's very nicely done too, I'm impressed by Cube. I got the Kathmandu Pro 625 on a cycle scheme for ~half price.
Stella63
27
Thanks. So as the one I've linked has MTB tyres then presumably the hard tail ride would be ok on rocky gravel paths.
Yak
105
39
For my ha’penny’s worth, I think full sus is unnecessary unless you are hammering fast rutted descents. As Nealh says, they steal your energy As soon as you start pedalling. A hard tail with low-pressure tubeless will give plenty of give, but ride well (and pressures can be increased for road use). I’m riding a gravel Orbea Gain with 38mm tyres over terrible trails. Not ideal, but it works, then when you hit the tarmac you soar.
Reactions: Nealh and simonsays
Stella63
27
Thanks. Yes this is where I get confused. Full suspension seems more than I need, but I keep reading that hard tail on emountain bikes is a no go for anything other than smooth trails as not the same as a hard tail on a regular bike. I quite like the comfort of a full suspension bike generally but it's more to maintain. (And I know nothing about maintaining :)
Reactions: simonsays
Stella63
27
My nearest hire centre/bike shop only deals with Orange bikes - we're out in the sticks many miles from big bike shops. Just wondering if there is an orange emtb that isn't too expensive.
Yak
105
39
That sounds silly. If they are talking about the extra weight, that
is meaningless as riders all weigh different amounts. If the bike is 4kg heavier because of the electric system, how does that effect me, at 120kg, and my mate, at 55kg? My Gain has zero suspension. I put 50psi in my 38mm tyres and ride bad trails. It works. I would be happier on bigger tyres, but Ikm not looking at suspension, at all, as I ride roads too.
simonsays
15
Depends what you expect and your previous experience I guess. You can't escape the bike's weight, so as standard, I found the bike crashes over the bumps (rather than skipping over as a light MTB might). The Big Bens I had have similar volume to the MTB ones, but I punctured early on and planned to go tubeless anyway (with the lower pressures you can use without fear of puncturing).
You've certainly got options in big volume tyres, if you need a softer ride. The rims are quite wide.
Reactions: Stella63
