Got one of these in an e-bay auction minus battery pack as I'm wiring it in. Impressed actually. Really small and very bright :
I can't mount on my seatpost as the light would be covered up so I adapted one of these to screw on to the mounting plate on the back of my rack :
Swivelmount for Magicshine / Inton / Fluxient / Starlight etc bike lights | eBay
I epoxied the slot-in light holder that came with the rack to the cut down bar :
... so I can easily attach my back-up battery-powered Smart Lunar 2 x 1/2W rear light if the built-in one fails or has to be turned off (e.g. if bike battery very low) :
There room to mount a second MJ-818 (not that you'd need it) ... or even (shock, horror) ... a rear reflector on the other side of the bar to keep all boxes ticked. Can't see any possible purpose to a reflector with lighting like that to be honest, but I don't make the rules !
The little bar attaches to my rack via a bolt from the rear into the cut down tubethat the emergency back-up light slot plate is epoxied to, held in place via a tricky to insert nut. But it works - and when I mount it, it can stay attached to the rack - as everything else can be removed.
Pleased with that.
Cut it down and swapped out the base plate for one of these mounts to fix it on to the bar :A T bar to fix your lights to.
Pleased with that.
