Going to put this on its own thread ....
Switch arrived from Germany today
. Now I just need to work out how to get it to work with my KU123 Controller !
A few basics for recap ... it's an in-line switch and I'm using it because my bike has XT combination brake/gear shift levers which I don't think will work well with a simple magnet-type solution. It's designed for BionX systems but I am told is compatible with others with some modifications, which I guess will be about the usual thing - where to connect and how to find compatible connectors !
Here's an exploded photo of the switch :
![20130207_130321[1].jpg](/forum/data/attachments/3/3683-bebe14c5780ce3132290dd2b9e1ee183.jpg)
The bits at the extreme ends are just rubber gland covers. Basically, the little gold pins insert into the brake line and introduce an increase in length of 4mm on each side. The line then slides through the threaded gland, then the small round-shaped piece is slipped on, and the gland screws in to the T-piece. There is a further 2mm to allow for the small piece in the middle of the T-piece between either end so the total increase in line length is 10mm.
There is a 2-wire connection to the switch and the wires are well sealed over with a sealing compound, and covered by a rubber boot which slides on tight.
So far so good - it's a well-made unit and cost about £30.
The other end has a connector like this, which appears to be a waterproof male connector sealed in :
![20130207_130512[1].jpg](/forum/data/attachments/3/3684-40ea7f2e5bf9d55620bc2211b40c88f3.jpg)
I guess on a BionX setup there would be a waterproof female attached to a cable which led to the controller. However this is not supplied and leaves me with the same old story I'm getting familiar with and envisaged happening - how to find a suitable coupling to take the connection to my controller... and where on the controller this fits into.
Does anyone know if you can buy leads with compatible female connectors already built in ? The length of cable attached to the switch is very short
rolleyes
so I am guessing the connector is likely to be external as a result and so a longer length coupling lead is likely to be most flexible for various controller locations.
