done bit of trawling on the net, quite like the look of the Kalkhoff Pro Connect Impulse Alfine 8G and it seems to get good reviews, any thoughts from you guys
many thanks
many thanks
I've had a Pro Connect for just over six years, but mine has the Panasonic motor, so I can't comment on the impulse system or the battery which accompanies it.done bit of trawling on the net, quite like the look of the Kalkhoff Pro Connect Impulse Alfine 8G and it seems to get good reviews, any thoughts from you guys
many thanks
many thanks for your contribution, i feel i'm getting somewhere, yes a test ride is a must that will be my next moveI've had a Pro Connect for just over six years, but mine has the Panasonic motor, so I can't comment on the impulse system or the battery which accompanies it.
My bike had done over 17000 miles and has had very few problems. I believe that this is due to the exceptional build quality of Kalkhoff bikes. There are other cheaper brands, but I doubt that they would withstand the punishment that a Kalkhoff is capable of absorbing.
The 8 speed Alfine hub gear has been fine for the whole 17000 miles. It did grumble for a few days at around 10000, but settled down again and has been its usual flawless self ever since. Some people report problems with Alfine / Bosch / Impulse motor combinations, but I've not heard of any direct experience of that on this forum, it's mainly hearsay or third hand reports.
I'm still using the original 6 year old 24 volt 10Ah battery, which gives about 25 miles range.
I don't think that Kalkhoff would have downgraded their range over the past 6 years, so I can only assume that they have improved on what I purchased.
If you are serious about this bike, you must test ride one before buying.
thanks for your comments and as a newbie on my first site i hope you'll excuse my inappropriate listing efforts? in response i would say improving my fitness, leisure cycling and commuting about 16 miles a day to work with some hills therefore using the car less frequently and two grand would be the limit i guessKalkhoff have a reputation for making fine bikes at a mid-to-high price point. However, the feedback you are after depends on what you want it for - what are your purchasing criteria? Overcoming a disability, improving your commute, leisure cycling, abandoning the car, exercise, reliability, affordability, etc? What's your budget and expected mileage? More detail = more help
(Minor aside: I may be spoiled by the other forums I post on, as they have posting guidelines that make for contributions that are easy to read. If you wouldn't mind not posting in bold-lower-case, and with a title that helps people decide what they would like to read, that helps a great deal. Here the title might be "Any thoughts on the Kalkhoff Pro Connect Impulse series?". Thanks!)
thanks jonah, i think i'll open a dealership in yorkshire - lol there doesn't seem to be anywhere round hereSorry, I see from your other post you're in Yorkshire. Loughborough would be the nearest location to try the Kalkhoff.
