Muddy Fox Electric Avenue issue
n101
Jul 28, 2025
Hello, new here. Bought a MF Electric Avenue (2021) second hand & it doesn't seem to take a charge, light comes on within the charger, has anyone had any dealings with 1 of these as don't want to but a battery if i don't need to. i've got in touch with MF for a manual & they won't entertain me as i'm not the original purchaser!
6,723
Torque-E-Cycles battery repair can bus specialists uk 01803 325945
thelarkbox
1,637
507
oxon
Do you have access to a multi-meter to take voltage readings from the battery?
If 0v output #1 check its switched on.., #2 there may be a fuse blown internal to the pack?
How long did you try charging it for?
Try posting pics of the bike/battery and connections. google suggests a couple of configs with a built in and or bolt on battery pack??
How old is the battery pack?
For a manual google for the display make/model, as this is the User interface to any/all inputs to the control system.. Tho muddy fox may have replaced the generic system to a) comply with local regs and b) f*ck with you..
