New headlamp!?
Citrus
176
That's huge!!!
:eek: Where did you get that Grizzly? And what is the power of it?
Grizzly Bear
282
Swansea
www.grizzlyfish.com
I bought it off Ebay, it's a "mini" spotlamp meant for a 4X4, I think it's supposed to go on a roll bar, I've also bought a voltage converter used in golf cars to bring the voltage down to 12v. The lamp came with a 55 watt H3 bulb, but I've found a 20 watt replacement from a Lambretta tuning company.
On my way to work there is a very dark road with pot holes, puddles (ice), rabbits, etc. hence the need, I can now also use cycle paths after dark, much safer than busy roads after dark!
giguana
216
that looks like a really decent headlamp. does it clip off easily?
Where did you find the voltage converter?
I'm very much converted to using light emitting diodes , in fact I have a lots and lots of red lights already mounted on some reflective plate which were for the back of Cadillacs in America, strong lumileds, I have lots extra, and I'm looking for some good white leds for the front. anyone want to swap?
Grizzly Bear
282
Swansea
www.grizzlyfish.com
Hi Giguana
it is very securely bolted on and wired in, I found the voltage converter on Ebay as well, it can convert 36 or 48 volts to 12 volts. I was using an LED headlight previously but found it lacked penetration, I still use it for road use where there's street lighting however.
Peter
giguana
216
Cheers for that, I have the same kind of headlamp on my bike but just in much smaller-5 W/36v...there are a couple of shops in the UK online with 5 W/36 v lightbulbs, I like the variety of powerful led's available and the durability, I definitely prefer the star and piranha types to the mass produced ones.
