Sounds like a ticking off Indalo, but thank you for your comments.
The website as it stands is far from completed and it is, as you say, a work in progress. There are several changes to come, but as it will be more than a month before I have stock to sell, it won't be finalised for a while.
As for the product, I believe that eZee have the best system in performance, options, reliability and value for money.
Just to clarify, I will not be selling bikes, to start with I will be selling conversion kits, bikes may come later.
Data
Meta data refers to key attributes in your page body that search engines may refer to and use when indexing your site.
Page Title
Title is one of the most important elements of your page. Does it reflect what the page is about? Will people search for this title?
Cyclezee Ltd - Home
Length Pass
Your title tag is 20 characters long. Your title tag should ideally be a maximum of 67 characters.
Single Character Pass
Your title contains 1 single character. This is an acceptable amount for describing your page title.
Search Engine Phrase Keyword Fail
We could not perform this test because you are on a free account.
Meta Description
The meta description attribute is used by most major search engines to generate a default description for your website. It is not always used (typically the snippet is related to the search term) but it is important to ensure your page meta description is readable and relevant to your page content.
Electric Bicycle Kits
Meta Description Pass
Your meta description tag is 21 characters long. Your meta description tag should ideally be a maximum of 154 characters.
H1 Heading
Your page should contain a H1 tag which describes the content of the page. Search engines may place a weighting on your indexing based on the content of the H1 tag.
H1 Usage Fail
You do not have a H1 tag on your page. A H1 tag or a Heading 1 tag is an important element that search engines may consider when ranking a site.
H1 Duplicate Fail
Your page has 0 H1 tags, ideally your page should contain one H1 tag. Use H2, H3 and H4 tags for sub-content.
Facebook is the worlds largest social network. Ensuring your site is integrated and being shared on it should be a priority if you are looking to increase your sites inbound marketing results.
