Non legal ebike conversion kit £49.99 ebay
Bonzo Banana
819
474
Saw this and must admit I bought the last front wheel conversion kit. At first I thought it was a scam but then realised the kit is non legal, it appears to be throttle control only. So wondered if that was the reason for clearing out cheap.
At the time of posting there is still two rear wheel conversion kits but remember these are not legal for uk roads as no cadence sensor on the crank. You'd either have to use it illegally or figure out how to add a cadence sensor that controls motor operation. Still legal to use a throttle control as long as the motor only works when you are peddling.
However the other issue is there doesn't appear to be a 250W mode so its illegal whatever I now realise.
RossG
1,628
1,646
No longer available so probably just clearing out old stock or could have been returns.
Bonzo Banana
819
474
Strangely I still see the 2 available but the buy button is now gone.
I wonder if I will get a cancellation.
3,994
It looks like they missed off the 1 from £149.99. If so, they'll most likely cancel. I hope you get it.
