Hi all,
I'm new to e-bikes and have been reading as much as possible over the last few weeks but I need the help of the experts here.
I'm putting together an e-bike as an experiment for casual use....I've made a few errors already, I bought a Chinese Ebay kit 24v 500w and found I could have done better from AlienOcean
I don't want to make any more mistakes if possible
As the kit is already on it's way I'm a bit stuck so will have to go with it, being 24v I *thought* it would be easier to use SLA's in combinations to get the required voltage and Ah....24Ah seemed to be a good choice given the loss due to the Peukert effect.....however with more reading 36v or higher would appear to be better...
So my question is should I stick with SLA or go with a 24v Ping or other LIFePO4 pack? I've identified some good SLA's from Denka and Yausa (like the TEV range) that promise longer life and come in at $140 or so for two but the size and 14.5Kg weight is a bit of a problem.
The Ping 24v 20Ah comes in at $344 and just under 5Kg but I'm not sure if that includes delivery...would a 500w motor kill the Ping pack?
I'm sort of leaning towards the Ping but I'm still a bit unsure....
Many thanks
Many thanks
