Onebot s6
ritzyboot01
Hi, I have a onebot s6 and it's showing ECN on the display and when I twist the throttle it shows an M and I have no drive or assist.
Does anyone have any idea what this is and how to fix? Thanks
4,245
Before anything else, make sure that the motor connector is in all the way to the marked line, not just in tight.
Ebikes rarely just get problems from nowhere. What changed just before the problem started or what were the circumstances when it started. Did you drop the bike, change a tyre, ride through a flood or what?
ritzyboot01
Thanks for replying, I changed the back tire and it worked fine for about 10 mins then the fault on the display.
4,245
Push the connector all the way in. If that doen't fix it, check that you didn't damage the cable where it comes out of the axle.
8,847
I followed your advise and it's now working again, Thanks for your help saneagle
Often a very common issue when work on a motor wheel is carried out.
I have lost count as has d8veh (one suspects) as to how many have had a similar issue.
Reactions: ritzyboot01
