Overshoes.
neptune
1,743
353
Boston lincs
We have had little rain lately, but as autumn moves into winter, we are bound to have more. I ride at least ten miles every day whatever the weather. Provided I have the right gear, I can actually enjoy riding in the rain. Much of my riding is on a pushbike rather than an e bike. So I need gear that does not impede pedaling. I always ride in trainers, rather than cycling shoes with cleats. I have some cheap cycling overshoes, but they have snags.
The material is a close weave nylon, the same stuff used to make lightweight overtrousers. They are very baggy and unsightly. If you needed to walk more than a few paces on the road, you would quickly wear a hole in the sole. There are numerous overshoes available, but for my purpose, they all seem to have the same snags.
1. They do not come far enough up the leg, and to ensure a watertight joint with your overtrousers, they would need to come probably halfway up to the knee. If water can run off the trousers into the overshoe, they aren`t a lot of good.
2. They all seem to be designed for use with pedal cleats, and so are bottomless. In a down pour, I suspect water splashed up from the road would still wet your shoes.
3. Ideally they need to have a light sole, to withstand walking on tarmac. They also need to be flexible at the ankle so as not to impede pedaling.
The odd thing is, I looked on Ebay a while back and saw some overshoes that met most if not all these requirements. There were several sellers of these, and I think they all came from China. I looked again today and could not find them. The best way to describe them is a lightweight see through Wellington boot, which appears to be made of the same plastic that is used for rain covers on pushchairs. In the photo, they appeared to have a sole, but I cant be certain of that. Has anyone seen these, or anything similar please?
Clockwise
438
53
I tend to just buy stuff from chain reaction, wiggle, decathalon and planet x bikes, not a fan of overshoes but you might find something you like.
Croxden
2,134
1,384
North Staffs
I give my trainers a good squirt of Scotch Guard. Seems to work.
Try these:
Totes Rubber Motorcycle Waterproof Over Boots Overboots Large L | eBay
I have a pair, which were used in the film "The Wall" by Pink Floyd. My friend and his mates got parts in the film as SS troops because they were tough-looking skinheads. They wore these overboots, which were painted silver, and as my friend was a biker, he kept them all afterwards and gave me a pair. His brother went on to a successful actor after years as an anti-social hooligan.
103Alex1
2,228
67
These are probably a close match to what you described - they are a sensible length to ensure water doesn't run down into the top of them if trousers ride up during cycling. Good quality and pretty lightweight too. They are open at the base though (like almost all cycling overshoes). I bought a pair last Winter but sent them back without testing outdoors as I bought some Gore-Tex Winter cycling boots instead.
VAUDE Rain overshoes GAITER LONG offers at the cycling shop Rose Bikes UK
GaRRy
1,019
Tamworth
Best solution ive found is 2 pairs of socks and 2 plastic bags. So one pair of socks then bags then other pair then put feet in shoes.
sent by pigeon post
jazper53
890
18
Brighton
Also Aldi is doing a lot of cycling gear, clothing, waterproofs, etc.
jackhandy
1,820
323
the Cornish Alps
Pretty much yer average pedelecelecker, then :cool:
Croxden
2,134
1,384
North Staffs
Eaglerider
374
47
East Sussex
After a fair bit of trial and error I have found these "Highland Walking" boots to fit the bill.
Highland Waterproof Boot at Cotton Traders
They are rubber wellington boots on the bottom half with a water resistant suede upper. I have tested them in extreme rain, (when the road is like a river), and they keep my feet warm and toasty. They are not bad to cycle in and have proved hard wearing. I have used them for walking as well and they remain comfy. They are very warm, if a little pricey at around £50.
RichB
143
15
Similar but a lot cheaper at Decathlon
http://http://www.decathlon.co.uk/weasy-boots-id_8227768.html
Croxden
2,134
1,384
North Staffs
Croxden
2,134
1,384
North Staffs
I have found them in a sale, see -http://www.cottontraders.com/story-by-postcode/trentham-gardens/stry/24 £22.50
neptune
1,743
353
Boston lincs
Many thanks for all the different suggestions. The boots suggested by d8veh were probably the closest to what I had in mind. They appear to pack into their own small bag, which means that they can always be carried in a pannier without taking up a lot of space, and they extend well up the leg, so that if the overtrousers are worn over the top of the overboots and secured with a bike clip, dry feet are guaranteed.
If d8veh happens to read this I have two questions. First am I right in thinking that the boot material is quite thin, and so will easily allow the ankle to bend in pedaling? Second, does the overboot have a sole, or is it partly or fully open at the bbottom?
