Oxygen Emate City 2011 / Link for a new chain ring if possible
georgehenry
1,455
1,273
Surrey
I wondered if anyone knows the correct style/BCD chain ring to order as a replacement for the standard 52 tooth one on my old Oxygen Emate City circa 2011. A link to one would be appreciared.
Also a link to a suitable replacement brake rotor. It attaches with six small bolts. I need one for the rear, which has warped but still works ok.
The road salt is reeking havoc!
3,994
Brake rotors are interchangeable. you can use any deign you like as long as it has the same siameter (written on it) and the 6 holes for the screws. 100s on Ebay. I think it's 180mm, but check anyway.
Chainwheels are also fairly standard. The important thing is the diameter of the fixing bolt circle (BCD), which you should measure. It's probably 110mm or 130mm. Obviously you need 5 fixing holes not 4.
Raboa
912
318
53
Oxygen website
It looks like oxygen used a prowheel crankset, to buy one now with that ring it states it is 130 BCD.
Spec sheet, please check right model.
https://pedelectric.wordpress.com/bikes-the-shortlist/oxygen-emate-city/ou can these chainrings from AliExpress, eBay, various cycles shops.
According to the spec sheet above it is 160mm six bolt (not Centrelock)rotors.
You can buy various makes and quality, you might be ok with a Shimano one. Disk brakes have improved over the years and got cheaper so I would consider upgrading your current ones.
I would phone / email oxygen to double check. I hope this helps, oxygen should be able to confirm any details.
8,790
Bolted rotors are a std 6 bolt fixing on most bieks/ebikes. The 5 bolt crank will likely be 110bcd but check with a tape.
georgehenry
1,455
1,273
Surrey
Thank you all for your kind replies. I used the "Understanding BCD" link from Raboa to measure the gap between two of the 5 bolts that attach my chain ring and confirm that it is 130BCD
I am about to look myself, but the Old Oxygen Emate City Road bike that I have two of has a single chain ring and if any of you found a suitable one on a website that you could add a link to I would again be grateful.
Thanks everybody for your help.
8,790
Raboa
912
318
53
The one you have shown looks like this one but cheaper, it would surprise me if both made in same factory but labeled differently.
